Showtec Solar FL-280
Uit assortiment
High Lightoutput
CRI >90
Wide range of beamshapers
Stand alone function
CREE LED
The Solar series offer an impressive light output in a compact but sturdy housing. It has a standard beam angle of 13 degrees which can be adjusted by the optional beam shapers. With a color temperature of 7400K combined with a CRI of 95 the Solar series are the ideal solutions for car shows, exhibitions and theme parks.
Voeding: 100 – 240 VAC
Stroomverbruik: 280 W
Vermogensfactor: 0.95
Gewicht: 7 kg
Afmetingen LxBxH: 468 x 261 x 266 mm
Behuizing: Die-cast aluminium
Kleur behuizing: Black powder coated
Certifcatie: CE
IP-classificatie: IP 20
Lichtbron: 14x 20W White LED
Kleurtemperatuur: 7500 K
Stralingshoek: 13 °
CRI: 95
DMX-kanalen: 2, 3
Lux op 2m: 73579 Lux
Lumen: 18000 lm
Koeling: Fan, Temperature controlled
Aansluiting voeding: Pro Power in- & output
Aansluiting DMX: XLR 3/5p In/Out
